SOF file won't compress into a POF file
Hi BaronBlackhawk,
I’m glad that somehow you've managed to perform a workaround to overcome this issue. When referring back to the Cyclone V Device Datasheet, on page 78, for Cyclone V E with member code A9, the recommended EPCQ serial configuration devices are able to store more than one image, for this case EPCQ256. Do you have any further questions? Else I would like to inform you that this thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
I would appreciate taking a moment to fill out the short survey with regards to your experience using Intel Forum Support.
If our support score is less than 9/10, I will value any feedback you can provide.
Fakhrul
