SOF file won't compress into a POF file
Hi BaronBlackhawk,
Just wanted to check, may I know that you have properly done the connection as per mentioned in the user guide as below?
Please refer: Cyclone V Device Handbook - Intel page 270
You also may enable Compression Before Design Compilation
To enable compression before design compilation, follow these steps:
1. On the Assignment Menu, click Device.
2. Select your Cyclone V device and then click Device and Pin Options.
3. In the Device and Pin Options window, select Configuration under the Category list and turn on
Generate compressed bitstreams.
Please let me know if this works for you. Thank you.
Fakhrul
- BaronBlackhawk3 years ago
I have done this. This had already been set. So far I've had the best luck with reducing the number of hardware multipliers I'm using.
The best I can tell, the amount of compression the tools provide isn't sufficient for all designs that should fit in the Cyclone. I don't know if I consider this a resolution to my problem. I have redesigned my filters to use fewer multipliers and I will see if it fits.
