BaronBlackhawk
3 years agoSOF file won't compress into a POF file
I have been slowly developing my FPGA code, and up until now, I have had no trouble fitting it into a POF file, but now I'm getting this message.
I'm developing for a Cyclone V (5CEFA9U19I7)...
FvM
3 years agoGuess it doesn't work. I see already 30 Mbit image size with A9 and 4% ALM utilization. Need 64 Mbit flash.
- BaronBlackhawk3 years ago
If I eliminate one stage of FIR filtering (using 20 hardwaree multipliers) it works. I can compile and it will produce a POF file that loads.
Changing to the EPCQ64A is problematic because it is a 16 pin soic not an 8 pin soic. I could probably scab one on but I think I'll try to reduce my multiplier usage by changing the number of taps in my filters.
