YDu00
7 years agosof and pof behaves differently for Max 10
I am using 10M04 FPGA. for some of the versions of my RTL project, if I download SOF file, it works great. if I download POF, it works partially right. this happends on all 3 boards that I have. any...
JohnT_Altera
7 years agoHi,
May I know if you have tried to performed system reset on your design to see if the functionality recover? I would like to understand if the configuration is causing the issue or the design is not reset correctly after power on due to external component driving the FPGA.
The reason is that I do not think that the FPGA is configured incorrectly which usually will cause configuration failure rather then entering usermode if the power is still not stable.
