8 years ago
Soc/HPS based on DE10-Nano : how do I program a DPR and/or UART
Hello everyone,
I am in a process of porting my application from a MAX10/DE10-Lite/NIOSII environment
(https://github.com/pdp11gy/dec-rl02-rl01-disk-emulator) to an SoC/HPC environment
based on the DE10-Nano board. At first I worked successfully with the DE0 Nano-SoC
board, but it did broke and I had to get the replacement board , DE10-Nano. And again,
here is a lot different. My main problem is in the I / O area. The PIO's are working
fine, but i have Problems with the Dual-Ported-Ram(DPR) and with an additional UART.
I am NOT able to copy data to and from the DPR via memcpy
In a NIOSII environment , it did work fine like this example:# define DPRAM_BASE 0x00100000 // Base-Address DPR# define DPRAM DPRAM_BASE
memcpy((void *)(DPRAM), &RLDRIVE.rl_drive_i[0], 11520);
In the SoC/HPC environment.
int fd; // Hold FPGA address
void *virtual_base; // Virtual addr that maps to physical
void *DPR_addr; // Dual Ported Ram address
DPR_addr = virtual_base + ( ( unsigned long )( ALT_LWFPGASLVS_OFST + DPR_BASE )
& ( unsigned long)( HW_REGS_MASK ) );
I did try the memcpy as following:
memcpy((void *)(DPR_addr), &RLDRIVE.rl_drive_i[0], 11520); // Not working
memcpy((void *)(uint32_t *)DPR_addr, &RLDRIVE.rl_drive_i[0], 11520); // Not working
.... and a lot of more tries.....but without success
Enclosed , please find the complete test c-programm.
Also, I am not able to load my .rbf file using de10_nano_linux. The following script
did work fine with the DE0-Nano-SoC unix but on the de10_nano_linux , I miss the Pass
/sys/class/fpga-bridge/fpga2hps/enable ....# !/bin/sh
echo 0 > /sys/class/fpga-bridge/fpga2hps/enable
echo 0 > /sys/class/fpga-bridge/hps2fpga/enable
echo 0 > /sys/class/fpga-bridge/lwhps2fpga/enable
dd if=RL_EMULATOR.rbf of=/dev/fpga0 bs=1M
echo 1 > /sys/class/fpga-bridge/fpga2hps/enable
echo 1 > /sys/class/fpga-bridge/hps2fpga/enable
echo 1 > /sys/class/fpga-bridge/lwhps2fpga/enable
My workaround is, to generate a .jic file and use the EPCS mode. I hope it has no influence
Any hint is welcome and many thanks in advance,
Reinhard
1 Reply
    I found the problem by myself, I did not care about the axi_master which is necessary for a dual_ported_RAM. Code has to be changed:
    # define ALT_AXI_FPGASLVS_OFST (0xC0000000) // axi_master
    # define HW_FPGA_AXI_SPAN (0x40000000) // Bridge span
    # define HW_FPGA_AXI_MASK ( HW_FPGA_AXI_SPAN - 1 )
    void *axi_virtual_base;
    axi_virtual_base = mmap( NULL, HW_FPGA_AXI_SPAN, ( PROT_READ | PROT_WRITE ), MAP_SHARED, fd,ALT_AXI_FPGASLVS_OFST );
    DPR_addr = axi_virtual_base + ( ( unsigned long )( DPR_BASE ));
    -> Now, also the memcpy works, see my example:
    memcpy((void *)(DPR_addr), &RLDRIVE.rl_drive_i[0], 11520); // RAM => DPR
    memcpy(&RLDRIVE.rl_drive_i[0], (void *)(DPR_addr), 11520); // RAM <= DPR
    I still have the problem, that I can't load my .rbf file
