12 years agoSoc EDS fail to connect to usb blaster
I have install Soc EDS v14 on centos 7, and run as doc ug_soc_eds.pdf secion “Getting Started with Bare-Metal Debugging” introduce, but when I Select Run > Debug Configurations and Click Brows...
12 years agoGood! Altera Guru, QuaPro and SigTap uses the same libjtag_client.so for work ?
"Failed to load libjtag_client.so" may be on small rights of .so: if need be executable +x ? May try 3 other versions of SoC EDS ver 13.*, its .so is worked ? Then will copy good .so to 14.0 directory... May be extended diagnostic of loading .so in any console with keys ? P.S. And may use many USB-Blasters and connect to board in round-robin -- if some by work ? :) In SoC kit present also 2nd USB-Blaster-connector (left-down corner) for external JTAG-device, with connecting to it 1st is automatic off. May try this way.
