12 years agoSoC Cyclone V example design : error->hierarchical path is too long
Hello Friends, I have altera SoC Cyclone V Board, and i am trying to understand the board using its gsrd located at "altera/Q13.1/embedded/example/hardware" . this design example is came along...
12 years agoNot exactly modify, i just create the symbol from ghrd_top.v
1. File-->Create/Update ---> Create Symbol file for Current File (ghrd_top.v) 2. File--> New File 3. Add the newel Created symbol (soc_system.bdf)-->add input and output port 4. Set as Top Level Entity 5. then Start Compilation ------------------------------------------------ if Once Again i remove the soc_system.bdf from project and recompile---> compile successfully
