15 years agosmoothing PLL output
Hi all I'm using a PLL on a cyclone III device to generate an 12.228 MHz clock from a 19.2 MHz input. the output clock is a square wave which causes harmonics that interferes with an RF appli...
15 years agoDid you try setting minimum slew rate for the output?
Maybe this will reduce some high frequency harmonics. You can also add a single capacitor to the output to obtain a more triangular wavwform.
