Slow Slew Rate
- 5 years ago
Hi @GD76
May I know does my latest reply helps?
Do you need further help regarding to this case?
Richard Tan
Hi @GD76
A slow slew rate reduces system noise, but adds a nominal output delay to rising and falling edges. The lower the voltage standard (for example, 1.8-V LVTTL) the larger the output delay when slow slew is enabled. Each I/O pin has an individual slew-rate control, allowing you to specify the slew rate on a pin-by-pin basis. The slew-rate control affects both the rising and falling edges. If no slew-rate control is specified, the Quartus software defaults to a fast slew rate.
For detailed functions, search for the keyword "Slew Rate" from the Device Handbook of each device and check.
Reference: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-v/max5_handbook.pdf
Richard Tan
- RichardT_altera5 years ago
Hi @GD76
Richard Tan
