12 years agoSingle address Avalon MM slave
<Accidentally posted this on the Nios General forum. My fault.> Quite often I create a peripheral that just uses a single word of data. The Avalon spec. states that the width of the address bu...
12 years agoWhat has the width of the address bus got to do with this?
If you are accessing avalon slaves from a Nios cpu then you really want to make your slaves have a 32bit data interface - even if you ignore all the high bits and return zeros on reads. If you have an 8bit slave then a 'bus width adapter' is inserted that converts the 32bit transfer into four 8bit ones with the byte enables set appropriately (ie 3 of the write requests won't have the byte enable asserted). Reads by the Nios always assert all 4 byte enables.
