12 years agosine wave generator
Hi to all, i want to generate high precision,low frequencies sinusoidal signals (50,80 and 180 hz) trough my altera cyclone4 (vhdl code) with the PWM technique. I've started to do some tests, i...
12 years ago --- Quote Start --- but the problem is that the only way to generate high precision 50hz signal is to set input clock frequency as a power of 2 (for example 65.536Khz). --- Quote End --- That's not the concept of NCO. You can generate arbitary frequencies with effectively unlimited accuracy and signal quality.
