15 years agosimulator problem
Probably missing something basic here but I set up a simple simulation with 8 data lines going into 8 d flipflops, a megawizard, with a clock input and 8 data line outputs. I changed several of the...
15 years agoOh yes, I do do that. But no matter how much ever I change the the clock signal to high or low, I get the same result. In some case, it takes the previous output result and then never change despite changing the inputs.
