15 years agosimulator problem
Probably missing something basic here but I set up a simple simulation with 8 data lines going into 8 d flipflops, a megawizard, with a clock input and 8 data line outputs. I changed several of the...
15 years agoI've never used the Altera simulator, but basically your clock signal needs to change regularly from 0 to 1 and the flip flops will only update their outputs on the rising edge of the clock. There is probably a button in the waveform creator that can automatically generate a signal that regularly switches from 0 to 1 for you.
