15 years ago
simulation result of "case" is one clk delayed?
totally, in the module "vnp" there are 256(parameter N=256) "cnt"s to deal with.
every "cnt" should go through a "Cycle".
One Cycle contains 3 steps. So the value of "Cycle" goes from 2'b00 to 2'b10 then retun 2'b00 like 00 01 10 00 01 10 00 01........ as the cnt grows 0 1 2 3......
that is
Cycle=0;
case(Cycle)
 2'b00:
  Cycle<=Cycle+1;
 2'b01:
  Cycle<=Cycle+1;
 2'b10:
  Cycle<=0;
  cnt<=cnt+1;
endcase
following is the detailed code
 always@(posedge Clk)
  if(CNP_ON||!CE)begin
   flag<=1;
   Cycle<=0;
   cnt<=0;
   calc_a<=0;
   calc_b<=0;
   Mess_Buff_a<=0;
   Mess_Buff_a<=0;
   Mess_Buff_a<=0;
   Mess_Buff_b<=0;
   Mess_Buff_b<=0;
   Mess_Buff_b<=0;
   end
  else
   if(cnt==0&&flag==1)begin
    cnt<=0;
    flag<=0;
    end
   else
    if(cnt==(N+1))begin
     cnt<=0;//reset cnt
     flag<=1;//reset flag
     end
    else
     case(Cycle)
      2'b00:begin
       if(!cnt)begin
        calc_a<={Mess_Din,Mess_Din,Mess_Din};
        Mess_Buff_a<=Mess_Din;
        end
       else begin
        calc_b<={Mess_Din,Mess_Din,Mess_Din};
        Mess_Buff_b<=Mess_Din;
        end
       Cycle<=Cycle+1;
        end
      2'b01:begin    //add SrcMem_Din in the second step
       if(!cnt)begin
        calc_a<=calc_a+{Mess_Din,Mess_Din,Mess_Din}
        +{SrcMem_Din,SrcMem_Din,SrcMem_Din};
        end
       else begin
        calc_b<=calc_b+{Mess_Din,Mess_Din,Mess_Din}
        end
       Cycle<=Cycle+1;
        end
      2'b10:begin
       if(!cnt)begin
        calc_a<=calc_a+{Mess_Din,Mess_Din,Mess_Din};
        calc_b<=0;
        end
       else begin
        calc_b<=calc_b+{Mess_Din,Mess_Din,Mess_Din};
        calc_a<=0;
        end
       Cycle<=0;
       cnt<=cnt+1;
        end
      endcase
in the simulation wave (in the attachment)
at the red line
cnt==0 flag==0 Cycle==0
so 2'b00 in case(Cycle) begin
       if(!cnt)begin
        end
       else begin
        end
       Cycle<=Cycle+1;
but the simulation wave has a delay of one clock
i have marked it out with yellow arrowhead
as you see Mess_Buff_a[0]<=Mess_Din should be run when Cycle==2'b00
but it happens at Cycle==2'b01
the waveform of Cycle and cnt are right
please explain
thank you
    --- Quote Start ---
    It doesn't happen at Cycle == 1. Mess_Buff_a[0] is updated in the same clock cycle when Cycle is incremented from 0 to 1, as your code commands. This is how synchronous logic works.
    --- Quote End ---
    thank you very much.
    I have misunderstanding the codes.
    the waveforms are right.
    --- Quote Start ---
    --- Quote End ---
