16 years agoSimulation in Quartus 10
Hi all,
I was used to simulate my project with the simulation tool in earlier version of quartus but now, this tool is no longer available with the version 10.0 and I have to use ModelSim. My questions are : Is there an easy way like "vector waveform file" to initiate the simulation or do I have to do all the stuff with command lines? Do you know a good tutorial to learn how to use ModelSim? Thank you15 Replies
--- Quote Start --- You need to convert them. The Quartus simulator never really supported them either - it only simulated a post place and route netlist. --- Quote End --- for me, as a simple user, it's the same thing. I guess that Modelsim does not support post fitter netlist? I really enjoy using graphic interface, and I don't think my company will purchase HDL designer... - Altera_Forum
The Quartus simulator never really supported them either - it only simulated a post place and route netlist. - Altera_Forum
does Modelsim support Quartus's design entry files (bdf, bsf) or do I need to convert everything to VHDL\Verilog?
Write a tesbench.
You've to set the Settings.. | simulation in order to compile the testbench. An example, combinatorial, testbench is the for a priority encoder following (remove line numbers): 1 `timescale 1ns/1ps // define simulation time units 2 module prenc83_tb(); // module with no inputs or outputs 3 reg [7:0] Atb; // reg net type. To be assigned in the initial block 4 wire [2:0] Ytb; 5 wire idle; 6 prenc83 d1(.A(Atb),.Y(Ytb)); // UUT named d1 7 initial // Just once at the beginning of the simulation 8 begin 9 Atb = 8'h01; // Eight bits hexadecimal value 10 # 100; // 100 time units delay -> 100 ns 11 Atb = 8'h02;# 100; 12 Atb = 8'h04;# 100; 13 Atb = 8'h08;# 100; 14 Atb = 8'h10;# 100; 15 Atb = 8'h20;# 100; 16 Atb = 8'h40;# 100; 17 Atb = 8'h80;# 100; 18 Atb = 8'h44;# 100; 19 Atb = 8'hF0;# 100; 20 Atb = 8'h00;# 100; 21 Atb = 8'hCF;# 100; 22 $stop; // System call that stops the simulation 23 end 24 endmodule For a sequential project you need a clock. It can be defined, in the testbench, as: // Generates the clock waveform parameter PERIOD=20; always begin CLKtb=0;# (PERIOD/2.0); // Delays by PERIOD/2 time units CLKtb=1;# (PERIOD/2.0); end - Altera_Forum
The easiest way to do this is in a testbench. You can write the testbench in your favourite HDL language and create waveforms to your heart's content, using direct assignments, waveform functions or reading from files. The Testbench is not going to be synthesised, so you can do loads of stuff you normally cant do.
What language do you normally create designs in?
