16 years agoSimulation in Quartus 10
Hi all, I was used to simulate my project with the simulation tool in earlier version of quartus but now, this tool is no longer available with the version 10.0 and I have to use ModelSim. ...
16 years agoWrite a tesbench.
You've to set the Settings.. | simulation in order to compile the testbench. An example, combinatorial, testbench is the for a priority encoder following (remove line numbers): 1 `timescale 1ns/1ps // define simulation time units 2 module prenc83_tb(); // module with no inputs or outputs 3 reg [7:0] Atb; // reg net type. To be assigned in the initial block 4 wire [2:0] Ytb; 5 wire idle; 6 prenc83 d1(.A(Atb),.Y(Ytb)); // UUT named d1 7 initial // Just once at the beginning of the simulation 8 begin 9 Atb = 8'h01; // Eight bits hexadecimal value 10 # 100; // 100 time units delay -> 100 ns 11 Atb = 8'h02;# 100; 12 Atb = 8'h04;# 100; 13 Atb = 8'h08;# 100; 14 Atb = 8'h10;# 100; 15 Atb = 8'h20;# 100; 16 Atb = 8'h40;# 100; 17 Atb = 8'h80;# 100; 18 Atb = 8'h44;# 100; 19 Atb = 8'hF0;# 100; 20 Atb = 8'h00;# 100; 21 Atb = 8'hCF;# 100; 22 $stop; // System call that stops the simulation 23 end 24 endmodule For a sequential project you need a clock. It can be defined, in the testbench, as: // Generates the clock waveform parameter PERIOD=20; always begin CLKtb=0;# (PERIOD/2.0); // Delays by PERIOD/2 time units CLKtb=1;# (PERIOD/2.0); end
