16 years agosimple socket sever is running,but cann't ping/telnet
I have meet a problem when use the simple socket sever templet in the niosii ide ecilipse,with weeks work but have no solution,so I post a thread here,maybe I could get help. My situation is here: hardware: cIII 120 develop board software: QII 9.1 sp2, Nios II 9.1 sp2 What i have done: 1. copy triple_speed_ethernet_design in the install directory to my project fold and open with QII 2. open sopc builder and run generate 3. back to QII and compile to generate sof (time limited version) 4. open nios eclipse ide, create a new project with simple socket server template ****************************************** 5. I disable DHCP in wizard and I use cross cable to connect board and PC directly. 6. run app as "Nios II hardware" what I got: =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: ================================================== === InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Static IP Address is 192.168.1.234 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x08004000 INFO : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=1, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.234 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) Everything looks smooth, but I cannot ping, telnet or whatever else. When I ping, the RX light is flashing, but TX light not. Thank you for your help!2 Replies
I am having EXACTLY this problem. I have used the standard design from the kit. I have had a field rep try the same thing, and get the same effect. It has been a very frustrating couple of weeks, and I am starting to doubt my sanity. I have tried the standalone lwip and I get a similar effect. Signal Tap shows packets correct on rgmii TSER_MAC statistics show correct broadcast ping statistics. Breakpoints in low level input show no packets received as always returning a null. Has anyone found a solution to this problem? Any advice appreciated! - Altera_Forum
Where did you get the triple_speed_ethernet_design from? Try to use the cycloneIII_3c120_dev_niosII_standard design from the files that Altera provides for the kit (here (ftp://ftp.altera.com/outgoing/devkit/cycloneiii_3c120_dev_kit-v9.0.2.exe)).
