MK_ABQ
Contributor
3 years agoSimple socket server - NIOS question
We are using simple socket server template in eclipse. Arria 10 GX devkit is used as hardware. Can see that ethernet link is established from NIOS console. But would like to understand if pi...
- 3 years ago
The icmp/ping function works on the Simple Socket Server example but ONLY on the Quartus 17.1 pro version. The Quartus version that you are using(18.1) cannot support the design example and ping function provided by Intel here: https://www.intel.com/content/www/us/en/design-example/714912/arria-10-nios-ii-simple-socket-server-design-example.html
I would suggest you to use Quartus 17.1 pro version to try out the design example above.
Thank you.
Kelly
KellyJialin_Goh
3 years agoHi,
Any updates from your side on the debugging steps provided?
Regards.
Kelly
