Simple socket server - NIOS question
- 3 years ago
The icmp/ping function works on the Simple Socket Server example but ONLY on the Quartus 17.1 pro version. The Quartus version that you are using(18.1) cannot support the design example and ping function provided by Intel here: https://www.intel.com/content/www/us/en/design-example/714912/arria-10-nios-ii-simple-socket-server-design-example.html
I would suggest you to use Quartus 17.1 pro version to try out the design example above.
Thank you.
Kelly
Hi Kelly,
Haven't had a chance to debug yet. Will try out TSE MAC loopback first and see the status.
Btw, I do not quite get the 3rd step
" For on board external host loopback, you can check your board to see whether it’s able to perform cable loopback somewhere on board." - What do you exactly mean by this? Can you kindly brief it?
MK
