16 years agosimple question on nios2 IDE
hi,
I have received a project (quartus with nios) from a coworker and I just wanted to open the software part in nios2 IDE 9.0. I can open que qpf project with vhdl and schematics very easily with quartus. I can open the sopc builder in quartus. I can open the *.c and *.h files in nios2 IDE 9.0, but I can't open the project!!! So I can't see the build options and I can't build it. Does anyone have any idea to do that? thank you.15 Replies
Be sure you have copied your folder into a path without "spaces". Please clean both projects and try a re-build.
Project->clean and project_>Build all. - Altera_Forum
I have imported both projects, but I cannot find where I have to choose the right .ptf file. I'm just asked for a directory when I import a project, and not for a .ptf file.
Did you import both user and system library projects?
Did you choose the rigth path for .ptf file when importing system library project? - Altera_Forum
I have done that, I have both my projects in nios2 C++ project view, but I can't build the project.
what do I have to choose for workspace? edit : when I go on properties->make_project->make_builder, I have : "builder is missing or disabled on project" - Altera_Forum
Right click on project navigator-> import...
On opened Dialog select "Nios II Existing Nios II IDE project into Workspace", "Next", search for project path clicking on button "..." near to "Project Contents" field. Accept cleaning project build files. Same procedure must be done for "syslib" project.
