15 years agoSimple new Component in Sopc
Hello, I'm a beginner with SOPC. The problem is: how can I create a SOPC component that interfaces to an external component, such as a full adder (x, y 8bit , sout 8bit, rout 1bit). This compo...
14 years agoI recommend the following:
1) Read the Avalon spec 2) Generate a simple component in SOPC Builder/Qsys like the on-chip memory component 3) Study the structure of the HDL to learn how to apply it to your own custom hardware Some recommendations: 1) Put byte enables on your slave port (allows you to perform sub-word accesses without corrupting the rest of the word) 2) Try to make the component fixed latency if possible (i.e. no need for wait request usually) 3) Don't over design. If you can simplify your component by using multiple ports then do it and let the tools handle the rest for you.
