17 years agoSimple Ethernet port.
I've been tasked with trying to get a simple ethernet port onto some of our specialty boards. For the most part they'd be used to send down control commands and read back simple status. Likely as not...
15 years ago --- Quote Start --- I'm using NIOSII + uCOSII + Interniche and a UDP modified version from the single socket server. I am very interested in using the Interniche stack TCP_IP without SO. How can I do it? --- Quote End --- Did you found an answer to your question? Thanks & Regards
