16 years ago
Silly error in 8 by 8 Bit Multiplier !!
Hi
Actually I have wrote a code for 8 by 8 Bit Multiplier
that uses CARRY LOOK AHEAD ADDER for the addition
But
The program gives me RIGHT results for some numbers and WRONG results for other numbers
So Can any one check the code for me and tell me where the problem is
Thank you very much
I appreciate your help
CODE:
entity Multiplier is
port
A : in bit_vector (7 downto 0);
D : in bit_vector (7 downto 0);
Result : out bit_vector (15 downto 0)
end entity;
Architecture M of Multiplier is
Begin
Process (A,D)
variable R : bit_vector (7 downto 0);
variable Carry : bit_vector (8 downto 0);
variable Cout : bit;
variable P : bit_vector (7 downto 0);
variable G : bit_vector (7 downto 0);
variable Sum: bit_vector (7 downto 0);
variable Temp1: bit_vector (7 downto 0);
variable Temp2: bit_vector (7 downto 0);
variable B : bit_vector (7 downto 0);
begin
R:= "00000000";
B:=D;
for i in 0 to 7 loop
If (B(0)= '1') then
Carry(0):= '0';
for j in 0 to 7 loop
G(j):= A(j) and R(j);
P(j):= A(j) or R(j);
Carry(j+1):= G(j) or (P(j) and Carry(j));
Sum(j):= P(j) xor Carry(j);
R(j):= Sum(j);
end loop;
Cout:= Carry(8);
Temp1:= R(0) & B(7 downto 1);
B:= Temp1;
Temp2:= Cout & R(7 downto 1);
R:= Temp2;
Else
B:= Temp1;
R:= Temp2;
End IF;
End Loop;
Result(15 downto 8)<= R;
Result(7 downto 0)<=B;
End Process;
End Architecture;
    Thank you for your reply
    But Actually I have to use the carry look Ahead Adder in my code
    So can you please check where the problem is in my code
    Thank you
    for an 8 bit adder, try this code instead:
    library ieee;
    use ieee.numeric_std.all;
    entity adder is
      port (
        A : in unsigned(7 downto 0);
        D : in unsigned(7 downto 0);
        result : out unsigned(8 downto 0)
    architecture rtl of adder is
    begin
      result <= ('0' & A) + ('0' & D);
    end rtl;
