Signed windows 10 USB-blaster driver
Hi Ton,
Can you try this? We have standalone windows 10 driver for USB Blaster
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2018/are-there-stand-alone-windows--10-drivers-for-the--intel--fpga-d.html
Thank You
- yong5 years ago
I am having the same issue to install USB Blaster II driver for Windows 10. The workaround by disable driver signature enforcement is not allowed by my company IT security policy.
I tried the fix on the link you posted. It does not work for me. The error message is:
"A problem was encountered while attempting to add the driver to the store."
I tried with Quartus 19.3 and 20.4. All the same error.
Do you have newer USB Blaster II driver? Or what can I do to fix this?
This is a bit urgent. Thanks!
- WillBill5 years ago
Yep... same here,
Tried to install the original driver aswell as the FIX driver.
Always the same error: (translated from dutch) A problem occured while attempting to add the driver to the archive.
Also here, company policy does not allow driver signature enforcement.
Urgently need to reprogram about 50 old Altera MAX7 devices.
Any solution ???
