GBuch1
3 years agoSignalTap reports invalid JTAG configuration
We are trying to SignalTap a Cyclone 10 device and are getting "invalid JTAG configuration" errors. This is the first time we have attempted SignalTap with the specific devices in this JTAG chain (...
ShengN_altera
3 years agoHi,
This link may be can help you out.
CAUSE: The current JTAG configuration is invalid. This message can occur because the board is not powered on, the programming hardware is not connected, there is a problem with the circuit board, you did not select a communications cable or a device, or you did not download a design with the current SRAM Object File (.sof).
ACTION: Make sure the circuit board is powered on, the programming hardware is connected properly, select a communications cable and device, and download the current SOF.
Sheng
