16 years agosignaltap question trigger
I am trying to tap into a module. The module works fine except sometimes randomly it stops working. I need to tap the last snapshot of the signals and acquire only the values when it hung. All the tr...
16 years agoDo you have a signal that changes just before the hang and that you can use as a trigger? If not what I would suggest is to create an additional signal that detects the hang and goes from 0 to 1 when it is detected. You can use this one as a trigger to see what happened before.
