17 years agoSignaltap II
Hi! I have two doubts. I have a proyect and I have created a *.stp file. I haven't used trigers conditions. The problem is that I want to see the captured dates continously in a 10ms ...
17 years agoI meant you can import data directly into MATLAB without using the QUARTUS for capture (you will need it to create the stp file).
look in the MATLAB help about the alt_signaltap_run command for more info. but as FvM said, you are limited by JTAG throughput (I have 1 Mbs in mind, but I'm not sure) , so you should better limit the data you need to transfer, use trigger conditions to "zoom in" on what intersts you.
