17 years agoSignaltap II
Hi! I have two doubts. I have a proyect and I have created a *.stp file. I haven't used trigers conditions. The problem is that I want to see the captured dates continously in a 10ms ...
17 years agoIf you have access to a logic analyser then you might be able to use that as they generally have larger sample depths but otherwise you will be constrained by the amount of ram you have available in your fpga.
