15 years agosignaltap II and MaxII
I can't get signal tap to work with my terasic MAXII micro kit . Does signaltap work with a cpld like MAXII ? If not is there another way to see how a programme works while running in the MAXII ?
In-system source&probe is available with MAX II and be used for some kind of debugging functions (not real-time, but e.g. switching test modes and reading static data).
Signaltap needs a lot of memory and does not work with current CPLDs.
To test your program in hardware you can use an fpga platform or logic analyser for ports.
