9 years agoSignalTap fails timing often
Hello, I have the following problem: When I try to use SignalTap to peek on some of my signals, it often shows values which are not sensible, which is often the result of timing violations betw...
9 years agoSignaltap is bound by the same constraints for the rest of the design - so if you have specified the clock constraints, the Timequest report will list any failed paths into signaltap
If there are no errors here, and you're still getting errors - then is it possible you are sampling some signals with the wrong clock?
