8 years agoSignalTap different sample depth led to different logic
Hi guys, I met a problem recently. I am using signaltap to capture some signals. When the sample depth is 2k, the signals are correct. But when I change the depth to 4k, some of the signals bec...
8 years agoAsynchronous paths are also an issue. They will not be timed, and their path delay will vary from build to build and with temperature.
Make sure everything is synchronised and everything is constrained.
