8 years agoSignalTap different sample depth led to different logic
Hi guys, I met a problem recently. I am using signaltap to capture some signals. When the sample depth is 2k, the signals are correct. But when I change the depth to 4k, some of the signals bec...
8 years agoYou should definitely at least constrain all clocks. Just because you don't see a timing failure doesn't mean anything unless the design is fully constrained.
