8 years agoSignalTap different sample depth led to different logic
Hi guys, I met a problem recently. I am using signaltap to capture some signals. When the sample depth is 2k, the signals are correct. But when I change the depth to 4k, some of the signals bec...
8 years ago --- Quote Start --- it depends if they are critical to the design you are checking. Do you also have some asynchronous paths into the logic? Did you check that the design met timing? --- Quote End --- Hi Tricky, Yes I have asynchronous paths in the logic. The timing is OK since the TimeQuest Timing Analysis is green and nike after compile design. The only timing related issues are some Unconstrained Paths shown above. Thank you! Leon
