8 years agoSignalTap different sample depth led to different logic
Hi guys, I met a problem recently. I am using signaltap to capture some signals. When the sample depth is 2k, the signals are correct. But when I change the depth to 4k, some of the signals bec...
8 years agoit depends if they are critical to the design you are checking.
Do you also have some asynchronous paths into the logic? Did you check that the design met timing?
