8 years agoSignalTap different sample depth led to different logic
Hi guys, I met a problem recently. I am using signaltap to capture some signals. When the sample depth is 2k, the signals are correct. But when I change the depth to 4k, some of the signals bec...
8 years ago --- Quote Start --- Does your design meet timing? 'Simply' doubling the RAM size may have ramifications on fit and timing. Make sure it meets timing. Cheers, Alex --- Quote End --- Thank you Alex. I only have some unconstrained paths: +---------------------------------------------------+ ; Unconstrained Paths ; +-------------------------------------+-------+-------+ ; Property ; Setup ; Hold ; +-------------------------------------+-------+-------+ ; Illegal Clocks ; 0 ; 0 ; ; Unconstrained Clocks ; 2 ; 2 ; ; Unconstrained Input Ports ; 3 ; 3 ; ; Unconstrained Input Port Paths ; 188 ; 188 ; ; Unconstrained Output Ports ; 33 ; 33 ; ; Unconstrained Output Port Paths ; 16901 ; 16901 ; +---------------------------------+-------+-------+ Could this be the problem? Thank you. Leon
