9 years agoSignalTap Can't Read Certain Signal
Hi!
I'm having problem with SignalTap. I was trying to use SignalTap to compare the archived project with the current developing one (they're mostly the same). However, I couldn't read some of the signals from the old project. I know that it is functional and I shouldn't be reading 0 for those signals. I checked technology map (post-fitting) and found that the old project's SignalTap module has much fewer ports then the current one. I'm thinking maybe that's the problem cause I can only read the signal in SignalTap if it's in technology map. Can any of you guys give me some advice on how to add in the signals? Thanks!1 Reply
It sounds like perhaps you've been tapping post-fit signals instead of pre-synthesis nodes. The weird names in the image you attached seem to confirm this. If changes are made to a design, there's no guarantee that post-fit signals will remain after another compilation, so Signaltap can't connect to them. I rarely tap post-fit nodes because of this. If you can, tap pre-synthesis nodes. These are also much easier to find because they are based directly off your HDL design. Use the Node Finder in Signaltap set to the pre-synthesis node filter or cross-probe to Signaltap from the RTL Viewer, not the Tech Map Viewer.
