15 years ago
SignalTab sometimes not working on Stratix III
Hello.
We've got problems with SignalTab II on Stratix III. Sometimes, after some compilation SignalTab stop working. When I run acquiring (Single Run or Autorun) it shows message "Acquiring pre-trigger data" and hangs in that state. It doesn't mean if I choose trigger conditions or not chosen trigger at all. Restarting acquiring in signaltab doesn't solve problem.
The only things that helps is changing project in some way - add/remove some probes in signaltab setup window and recompile project.
Device: Stratix III EP3SL110F1152C2
Quartus 9.1 sp2
Windows XP SP3
One compilation takes about 20-30 minutes, so it very boring to find that after some changes in project Signaltab not working.
Please help!
    --- Quote Start ---
    Of cource, it supports this frequency, because it C2 speed grate. Anyway, we were tring to slow speed of sampling in SignalTab to 200 or 100 Mhz. And we had same problems with:
    "Acquiring pre-trigger data"...
    --- Quote End ---
    any setup or hold time violations ? Hold time violations could not be solved by reducing the clock speed.
    Kind regards
    GPK
    --- Quote Start ---
    We are using ALT_PLL output - 400 MHz, which is made from input clock 10 MHz.
    --- Quote End ---
    are you sure that signaltap could run at that speed ? No timing violations in the timing reports ?
    Kind regards
    GPK
    --- Quote Start ---
    Hello.
    Quartus 9.1 sp2
    Windows XP SP3
    Please help!
    --- Quote End ---
    what clock are you using for capturing the data ?
    Kind regards
    GPK
