15 years agoSignalTab sometimes not working on Stratix III
Hello. We've got problems with SignalTab II on Stratix III. Sometimes, after some compilation SignalTab stop working. When I run acquiring (Single Run or Autorun) it shows message "Acquiring pre...
15 years ago --- Quote Start --- Hello. We've got problems with SignalTab II on Stratix III. Sometimes, after some compilation SignalTab stop working. When I run acquiring (Single Run or Autorun) it shows message "Acquiring pre-trigger data" and hangs in that state. It doesn't mean if I choose trigger conditions or not chosen trigger at all. Restarting acquiring in signaltab doesn't solve problem. The only things that helps is changing project in some way - add/remove some probes in signaltab setup window and recompile project. Device: Stratix III EP3SL110F1152C2 Quartus 9.1 sp2 Windows XP SP3 One compilation takes about 20-30 minutes, so it very boring to find that after some changes in project Signaltab not working. Please help! --- Quote End --- Hi, what clock are you using for capturing the data ? Kind regards GPK
