15 years agoSignalTab sometimes not working on Stratix III
Hello. We've got problems with SignalTab II on Stratix III. Sometimes, after some compilation SignalTab stop working. When I run acquiring (Single Run or Autorun) it shows message "Acquiring pre...
15 years ago --- Quote Start --- We are using ALT_PLL output - 400 MHz, which is made from input clock 10 MHz. --- Quote End --- Hi, are you sure that signaltap could run at that speed ? No timing violations in the timing reports ? Kind regards GPK
