10 years agosignal tap with USB blaster II
i have just bought a USB blaster II to upgrade the Altera / TerASIC USB blaster that i have been using ( all off the back of a dodgy USB hub it transpires ) if i use the old USB blaster as i ha...
10 years agoHi,
something I saw before is that sometimes the signal tap library gets messed up. Then just delete the stp file and make sure it is not added to the project anywhere. Then recompile ensuring there is nothing left. Finally setup the signal tap with the correct hardware. I hope this is of any help and worth a try. You might want to use a revision trying this. :) ~fade
