Signal Tap Start-up failure
This is my first time seeing this kind of behavior. So, I am quite stumped.
Curious, does the device part name show up correctly in the working machine? instead of 0x2E320DD
Do you mind to share the project so I could check whether the same issue occur from my side?
Richard Tan
Hi Richard,
I have fixed the problem by reinstalling the USB Blaster driver of rev.20.4 (rev.19.1 was failed with " file corrupted" info). Partially reason, I guess, might be that I did not have administrator level authority for the machine. The system just blocks it. But, I still don't know why it was working at the beginning when I installed the Quartus two years ago and later it became failure. Perhaps it was intervened by some security software installation since then. What I did today was just wiped out the driver totally and reinstall it with the admin authority. It works now. Weird, isn't it?
Anyway, very appreciate your helps!
Yaoting Yang
AEM America, Inc.
