Yt_aem
3 years agoSignal Tap Start-up failure
I am using Quartus Prime Pro 19.1 and device is Cyclone 10GX150.
Using SFL to program the device is successful over the JTAG (See attached SFL.png). But, when opening the Signal Tap, it keep...
sstrell
3 years agoThe hex address is just an identifier for a device on the JTAG chain. The actual part number usually appears in the Programmer or here in the .stp after Scan Chain. Is it programming successfully in the Quartus Programmer with the .sof file directly? Something seems fishy.
Yt_aem
3 years agoYes. It is programmed successfully.
And also the programmer shows the correct part. But in signal tap it shows a device id number. I am not sure if they are identical.
