Yt_aem
3 years agoSignal Tap Start-up failure
I am using Quartus Prime Pro 19.1 and device is Cyclone 10GX150.
Using SFL to program the device is successful over the JTAG (See attached SFL.png). But, when opening the Signal Tap, it keep...
sstrell
3 years agoIgnore the status. Just try start running the logic analyzer after you've programmed the device. I bet it will work. That status is not accurate if you don't program the device in the JTAG Configuration section of the .stp on the right, as mentioned. And is the correct device selected there (0x02E320DD? Usually the device part number will appear here)?
Yt_aem
3 years agoNo, it does not work right after programing the device.
It is "0x02E320DD" shown under the JTAG Chain Configuration tab,
But, what does it mean? I am using 10CX150YF672E6G device, a Cyclone 10gx FPGA.
