signal tap data error when depth increased more than 512b
Unfortunately, your screenshot doesn't really show anything pertinent to the issues you mention other than the fact that it looks like you are trying to capture 1060 signals/channels. What size and setup is the buffer (not shown in your screenshot)? Are you able to successfully compile the design and program the device? Any error or warning messages? How full is your device? What leads you to believe you have corrupted captured data?
Please see i have attached .stp file.
<Are you able to successfully compile the design and program the device? >
Yes, i am ble to program the device.
<Any error or warning messages? >
No error messages.
<How full is your device? >
less than 10% of device resources
; Fitter Summary ;
; Fitter Status ; Successful - Wed Nov 2 19:07:24 2022 ;
; Quartus Prime Version ; 20.1.0 Build 177 04/06/2020 SC Pro Edition ;
; Revision Name ; A10_LFPS_PMA_02 ;
; Top-level Entity Name ; pcs_pma_top ;
; Family ; Arria 10 ;
; Device ; 10AX115S2F45I1SG ;
; Timing Models ; Final ;
; Power Models ; Final ;
; Device Status ; Final ;
; Logic utilization (in ALMs) ; 18,392 / 427,200 ( 4 % ) ;
; Total registers ; 24823 ;
; Total pins ; 54 / 960 ( 6 % ) ;
; Total virtual pins ; 0 ;
; Total block memory bits ; 543,744 / 55,562,240 ( < 1 % ) ;
; Total RAM Blocks ; 29 / 2,713 ( 1 % ) ;
; Total DSP Blocks ; 0 / 1,518 ( 0 % ) ;
; Total HSSI RX channels ; 1 / 72 ( 1 % ) ;
; Total HSSI TX channels ; 1 / 72 ( 1 % ) ;
; Total PLLs ; 3 / 144 ( 2 % ) ;
< What leads you to believe you have corrupted captured data>
Its known data/pattern.
512 depth NO corruption, 1k depth same file only modified stp data is corrupted(not matching to actual data).
