17 years ago
Signal has no source
Hi All!
When i compile the following code: (Quartus)
entity ISA is
port
--from ISA to CPU
(AEN_IN,IOR_IN,IOW_IN :inout std_logic;
ADDR_IN : inout std_logic_vector(10 downto 0);
DATA_IN :inout std_logic_vector(7 downto 0);
--from CPU to ISA
DATA_OUT :inout std_logic_vector(7 downto 0) );
end ISA;
architecture arch of ISA is
signal DATA_BUF : std_logic_vector(7 downto 0);
begin
process(IOW_IN,IOR_IN)
begin
--write operation
if IOW_IN'event and IOW_IN = '0' then
if ADDR_IN = B"01000011000" AND AEN_IN ='0' then
DATA_BUF <= DATA_IN ;
DATA_OUT <= DATA_BUF ;
else
DATA_OUT <= "ZZZZZZZZ";
end if;
end if;
--read operation
if IOR_IN'event and IOR_IN = '0' then
DATA_IN <= DATA_OUT;
end if;
end if;
end process;
end arch;
I get warnings:
Warning: The bidir "AEN_IN" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "IOR_IN" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "IOW_IN" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[0]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[1]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[2]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[3]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[4]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[5]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[6]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[7]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[8]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[9]" has no source; inserted an always disabled tri-state buffer.
Warning: The bidir "ADDR_IN[10]" has no source; inserted an always disabled tri-state buffer.
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[0]~7 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[1]~6 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[2]~5 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[3]~4 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[4]~3 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[5]~2 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[6]~1 that it feeds
Warning: Inserted an always-enabled tri-state buffer between logic and the tri-state bus DATA_IN[7]~0 that it feeds
Warning: TRI or OPNDRN buffers permanently enabled
Warning: Node "DATA_IN[0]~16"
Warning: Node "DATA_IN[1]~17"
Warning: Node "DATA_IN[2]~18"
Warning: Node "DATA_IN[3]~19"
Warning: Node "DATA_IN[4]~20"
Warning: Node "DATA_IN[5]~21"
Warning: Node "DATA_IN[6]~22"
Warning: Node "DATA_IN[7]~23"
And i have no idea what the warnings mean.
Could someone help me to figure it out?
Thanks!
    Yes, DATA_IN is a bi-directional signal but you don't get a "Signal has no source" warning about DATA_IN.
    The warnings about DATA_IN simply say that the signal is never tri-stated so it's tri-state buffer is always enabled.
    Thanks for the valuable information.
    Actually DATA_IN is bidirectional, i read from and write to it.
    You've defined the signals as INOUT but only used them as inputs so it has disabled the tri state buffer because it never ouputs a value.
