11 years agoSignal distortion ADC/DAC on Cyclone III dev kit
Hi All, I'm new to FPGA's, and have been having difficulty doing basic signal I/O. I modified the factory example that came with the Cyclone III software (see attachment for block diagrams)....
11 years ago"It would be useful if you posted images of the ADC output (captured using a scope) and the DAC data plotted using say MATLAB's stair() function (so that it looks like sampled data)."
Attached is a picture taken from an oscilloscope. The blue signal is 2V p-p and is the sinusiodal output from a function generator at 1MHz. The yellow is the corresponding output from the FPGA DAC with ~50mV p-p. As for the ADC, do you recommend using the SignalTap II logic analyzer for analog aquisition? "Can you post a link to the specific board(s) you are using, so that we can see what ADC/DAC is used." I'm using the Cyclone III DSP Development kit with an HSMC data conversion card: https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-cyc3-dsp.html The ADC is the Analog Devices AD9254, and the DAC is the TI DAC5672: http://www.analog.com/media/en/technical-documentation/data-sheets/ad9254.pdf http://www.ti.com/lit/ug/slau139b/slau139b.pdf "What frequency are you trying to generate? Many ADC/DAC kits have balun/transformer inputs/outputs which limit the range of frequencies you can test with." The goal is to use a frequency comb filter on an analog-->digital signal and then delay that signal by some amount before converting it back digital--> analog. The frequencies should be from 1 - 75MHz (nyquist frequency of the ADC) The HSMC card features transformers, so that shouldn't be the issue. , but their frequency range is .004 - 300MHz http://www.minicircuits.com/pdfs/tt1-6-kk81.pdf I will definitely check out those documents you mentioned! Thanks! Chris
