11 years agoSignal distortion ADC/DAC on Cyclone III dev kit
Hi All, I'm new to FPGA's, and have been having difficulty doing basic signal I/O. I modified the factory example that came with the Cyclone III software (see attachment for block diagrams)....
11 years agoHere's the DAC output connected to an oscilloscope (see attachment). The blue signal is output from a function generator, 2 V p-p. The yellow is output from the ADC, 50mV p-p. As for the ADC into the board do you recommend using the SignalTap II logic analyzer to acquire data?
I'm using the Cyclone III DSP Development Kit with an HSMC card: https://www.altera.com/products/boards_and_kits/dev-kits/altera/kit-cyc3-dsp.html Here's info for the DAC: (TI DAC 5672) http://www.ti.com/lit/ug/slau139b/slau139b.pdf and ADC: (Analog Device AD9254) www.analog.com/media/en/technical-documentation/data-sheets/ad9254.pdf I'm working from 1 MHz to 75MHz (since the ADC sampling rate is 150Msps). The DAC/ADC are transformer-coupled, and looking physically on the HSMC card, these are the transformers with a frequency bandwidth of .004 to 300 MHz, which is plenty. http://www.mcl-yokohama.co.jp/webdata/tt1-6-w38.pdf I'll start reading through the EELive! slides and ESC paper. Thanks! Chris
