15 years ago
signal delay
Hi All!
I need some delay on bus:
if SEL <=  '1' then
  BUS <= BUS1;
else
  BUS <= "0110";
  HERE I NEED DELAY 1 SECOND
  BUS <= BUS1;
end if;
I was trying:
BUS <= "0110";
BUS <= BUS1 after 1000 ms;
it compiles but doesn't work.
    The below code assumes, that SEL is synchronized to clk50. Otherwise additional code will be required.
    constant DELAY: integer := 5000000; -- assuming 50 MHz clock
    signal delcnt: integer range 0 to DELAY-1;
    signal sel_del: std_logic;
    process (clk50)
    begin
      if risisng_edge(ck50)
        if SEL = '1' then
          delcnt <= DELAY-1;
          sel_del <= '1';
        elsif delcnt > 0 then
          delcnt <= delcnt - 1;
          sel_del <= '1';
        else
          sel_del <= '0';
        end if;
      end if;
    end process;
    process (SEL, sel_del, BUS1)
    begin
      if SEL =  '1' then
        BUS <= BUS1;
      elsif sel_del = '1' then
        BUS <= "0110";
      else
        BUS <= BUS1;
      end if;
    end process;
    Thanks for the answer. Can you provide some example for 100 ms?
    SEL signal can not be delayed - it has its own driving logic.
    VHDL delay statements aren't synthesizable. They are intended only for simulation and simply ignored in synthesis. You need to generate a delayed SEL signal, involving a clock and a delay counter.
