15 years agosignal delay
Hi All! I need some delay on bus:
if SEL <= '1' then
BUS <= BUS1;
else
BUS <= "0110";
HERE I NEED DELAY 1 SECOND
BUS <= BUS1;
end if;
I was trying: BUS <= "0110"; BUS <= BU...
15 years agoThe below code assumes, that SEL is synchronized to clk50. Otherwise additional code will be required.
constant DELAY: integer := 5000000; -- assuming 50 MHz clock
signal delcnt: integer range 0 to DELAY-1;
signal sel_del: std_logic;
process (clk50)
begin
if risisng_edge(ck50)
if SEL = '1' then
delcnt <= DELAY-1;
sel_del <= '1';
elsif delcnt > 0 then
delcnt <= delcnt - 1;
sel_del <= '1';
else
sel_del <= '0';
end if;
end if;
end process;
process (SEL, sel_del, BUS1)
begin
if SEL = '1' then
BUS <= BUS1;
elsif sel_del = '1' then
BUS <= "0110";
else
BUS <= BUS1;
end if;
end process;
