haduchieu's avatar
haduchieu
2 months ago
Signal counts incorrectly on EP4CE6E22C8N while others signal work fine (same code Verilog)
I am facing a strange issue on FPGA EP4CE6E22C8N (Cyclone IV), i use quartus II 13.0 and signaltap to debug.
I have three input signals running in parallel, using the same HDL code and the same timing standard.  Two signals work correctly, but one signal always counts incorrectly, even though the input waveform itself looks correct so i donn't know problem is hardware,software, setup quartus or all of its.
 Design description
- The module counts the length of LOW level of signal inside a valid window.
- The longest LOW segment is stored as max_len and max_pos.
- The input signal is synchronized using a 3 flip-flop synchronizer.
- Debugging is done using SignalTap, and the input signals are confirmed to be correct.
 Verilog Source Code
module counter_max_in_segN
    parameter SEG_N_START_PIXEL_NUMBER,
    parameter SEG_N_END_PIXEL_NUMBER,
    parameter OFFSET_SEG_N,
    parameter MAX_CLK_COUNTER
    input  wire clk,
    input  wire rst,
    input  wire sp,
    input  wire vN_signal,
    output reg  [9:0] out_len,
    output reg  [9:0] out_pos,
    output wire be_cover
reg [2:0] vN_sync_reg = 3'b111;
wire vN_clean;
reg [9:0] clk_counter     = 10'd0;
reg [9:0] max_len         = 10'd0;
reg [9:0] max_pos         = 10'd0;
reg [9:0] counter_shadow  = 10'd0;
reg [9:0] counter_pos     = 10'd0;
reg       becover         = 1'b0;
assign be_cover = becover;
always @(posedge clk) begin
    vN_sync_reg <= {vN_sync_reg[1:0], vN_signal};
    if (sp || ~rst) begin
        clk_counter    <= 10'd0;
        max_len        <= 10'd0;
        max_pos        <= 10'd0;
        out_len        <= 10'd0;
        out_pos        <= 10'd0;
        counter_pos    <= 10'd0;
        counter_shadow <= 10'd0;
        becover        <= 1'b0;
    end else begin
        clk_counter <= clk_counter + 1'b1;
        if (clk_counter > 10'd71 &&
            clk_counter <= SEG_N_END_PIXEL_NUMBER + 10'd71) begin
            if (vN_clean == 1'b0) begin
                becover        <= 1'b1;
                counter_pos    <= clk_counter - 10'd71;
                counter_shadow <= counter_shadow + 10'd1;
            end else begin
                becover <= 1'b0;
                if (counter_shadow >= max_len) begin
                    max_len <= counter_shadow + 10'd3;
                    max_pos <= counter_pos;
                end
            end
        end
        else if (clk_counter > 10'd288 + 10'd71 &&
                 max_len != 10'd0 &&
                 max_len <= max_pos) begin
            out_len <= max_len;
            out_pos <= max_pos + OFFSET_SEG_N + 1'd1;
        end
    end
end
assign vN_clean = (vN_sync_reg == 3'b000) ? 1'b0 : 1'b1;
endmodule
Declare in top module
counter_max_in_segN  #(.SEG_N_START_PIXEL_NUMBER(10'd1), .SEG_N_END_PIXEL_NUMBER(10'd216), .OFFSET_SEG_N(10'd0), .MAX_CLK_COUNTER(10'd380))
counter_seg1(
.clk(cp),
.rst(_rst),
.sp(sp),
.vN_signal(v1),
.out_len(out_len_1),
.out_pos(out_pos_1)
counter_max_in_segN  #(.SEG_N_START_PIXEL_NUMBER(10'd1), .SEG_N_END_PIXEL_NUMBER(10'd216), .OFFSET_SEG_N(10'd216), .MAX_CLK_COUNTER(10'd380))
counter_seg2(
.clk(cp),
.rst(_rst),
.sp(sp),
.vN_signal(v2),
.out_len(out_len_2),
.out_pos(out_pos_2)
counter_max_in_segN  #(.SEG_N_START_PIXEL_NUMBER(10'd1), .SEG_N_END_PIXEL_NUMBER(10'd287), .OFFSET_SEG_N(10'd432), .MAX_CLK_COUNTER(10'd380))
counter_seg3(
.clk(cp),
.rst(_rst),
.sp(sp),
.vN_signal(v3),
.out_len(out_len_3),
.out_pos(out_pos_3)
 Summary
 I try change pinout but has same problem above, the third signal always read wrong so i want to know what and why make this problem and also how to fix it?
Thanks for all help.
Result of signaltap
    • haduchieu's avatar
      haduchieu
      hello, the problem has overed when i connect board to oscilloscope, must be impedance matching problem about my board
